JANUARY - 8th- Wellington
- Guest user
Shell petrol, West Buckland road Wellington. Meet 09.30 to leave 0945, fuelled for 90 miles.
Breakfast At Yandles Martock.
https://goo.gl/maps/2Azei2cXsnYGwgmS8
Pace will be making good progress according to prevailing conditions. Not hanging about for 125s but knee sliders not required either.
Weather dependant, so check here if I postpone to later in the month.
We could make this New Years day for the first '23 ride, thorts pleeze???
1960 BSA A10
1960 BSA A10
Re: JANUARY - 8th- Wellington
I'm right around the corner from Shell so will join you if the weather isn't total rubbish
If there's no salt around then I'm up for this
- Robbo87
- First Name: Phil
If the Trumpet is up to it then so am I; so TBC.
Triumph Sprint ST 1050.
- Robbo87
- First Name: Phil
Brian, I'll meet you and the gang in the Devonshire Inn layby, the one with 'Max's Cabin' in it at the junction of the A303 and A30 (EX14 9NE) at 10.00 a.m. - weather permitting.
I won't make the New Years Day alternative date, no matter what the weather does.
- Guest user
That would mean reversing the loop of the route from clockwise to anticlockwise. No problem, though I doubt we'd be at Max's for 10.00. Might do it in summer
but in January more like 10.10
1960 BSA A10
1960 BSA A10
- Robbo87
- First Name: Phil
If you want to make Martock for brekky then anti-clockwise is deffo the best option, we'll be there by 11.00 a.m.
If you went clockwise we'd be hard pressed to make it for midday.
But if you want to do Phil, you could always post up your own ride on an alternative day.
Then Brian can suggest other plans to you.
Count me in for the 8th Phil. Could also do 1st Jan.
- Tvrv37
- First Name: Phil
In the diary, weather and road salt allowing.
- Guest user
I'm not changing it to the 1st. Ride will be on 8th. The loop reversed to pick up Phil the elder:-
https://goo.gl/maps/wKXXjwEqVBH5WLXBA
Route is not written in stone and may well be modified on the day if the lesser roads are particularly dodgy and the A30 east of Yarcombe might be closed. I'll check for roadworks etc before the day.
1960 BSA A10
1960 BSA A10
Yes, count me in for the ride Brian. Will meet you at Wellington.
Looking at the future weather, it looks like it,s stormy. 10/11mm with lightening - Mmmm.
Maybe the forecast is wrong.
Anyway I hope so.
- Guest user
Usual winter scenario. If the weather looks to be particularly foul I'll cancel. So peeps need to check here on the morning before setting out.
1960 BSA A10
1960 BSA A10
- Robbo87
- First Name: Phil
The forecast looks not too bad thus far: https://www.metoffice.gov.uk/weather/fo ... 2023-01-08
