Then I pressure washed the bike with our hot pressure washer, shamyed it off and had a coffee while it dryed. I put it on the ramp and took the pads out of the calipers, cleaned up the pistons, pads, etc and put some copper slip on the back of the pads, pins, etc.
I also put a new rear on, a Michellin Pilot Power. While the wheel was out I put the sprocket hub on the spindle and back into the s/arm so that I could get the rust of the back of the chain using my die grinder and a brasss cup wire brush. While the wheel was out I cleaned up the s/arm and applied some ACF-50. I also put it on the spacers etc.
Once the wheel was back in I applied the ACF-50 the the rest of the bike (except plastics), even the chain, by spraying it on or by brush and then cleaned the tyre walls. I then sprayed the black plastics with cockpit shine silicone and polished the fairing.
By the time I'd finnished the bike looked sweet. I took the camera with me so I could put some pics on this post but cos our my camera uses more power than HMS Ocean I only got one pic before the battery died (forgot to chage them). I rode it home on damp roads and it has obvoiusly got dirty again but I knew that was gonna happen. The whole idea was to get some preservative on it so it didn't corrode through winter. Because I used ACF-50 it will last for another year before I have to apply it again, the stuff eats salt and corrosion and was developed for the yanks to use on their navey aircraft.
If the bikes not to bad (my garage isn't lit) I'll take some more pics in the morning and add them.
Here's the link to the ACF-50 webpage. We sell it at Taylors for £13 a can which will last for ages, I hardly used any of the can today
http://worldwideaviation.co.uk/Motorcyc ... 20Main.htm
And if you also have a Triumph the best TFR (Traffic Film Remover) to use is CB25 Superbike wash which we also sell. This is because all the others I've tried (I'm a bike valeter so I've tried a lot) make the black on Triumphs go whiteish.
The bike was still clean in the morning so I took this pic. Check the rest out at
http://mikepparker.spaces.live.com/?_c1 ... 02_owner=1
For some reason I could only download 3 onto the site
