PC Help Needed
speedy(delboy)
PC Help Needed
Post by speedy(delboy) »
My daughters PC wont start up properly :? :?
It turns on, starting the loading thingy, then comes up with start in Safe Mood etc etc, weather you say safe mood or not, it just sits there trying to restart again and again and again ending up always on the safe mood page :?: :?: :?:
Anyone :?: :?:
Please only reply if ya know what your talking about, as my daughter is giving me grief and i need this sorted. Cheers
check to make sure sure she doesn't have any bits like external hard drives plugged in, mine comes up with that message if i live a portable drive plugged in
So it constantly reboots itself? no matter if you choose to boot normally or in safe mode?
Sounds buggered! Unlucky!
Either a re-install of windows or at worst, faulty hardware. Easiest way to find out if it's a hardware fault would be to download this diagnostic boot cd (It wont effect anyone on the HDD) http://www.ultimatebootcd.com/ then run through the Memory/CPU/Benchmark tools to see if any fail/crash. If they work fine, it's most likely a software issue and you'll need to format and reinstall (could try to reinstall over the top if you need to keep stuff)
gixerdrew
Post by gixerdrew »
Turn it off to cool down for 30mins & try again
speedy(delboy)
DynaMight wrote:So it constantly reboots itself? no matter if you choose to boot normally or in safe mode?
Cheers Gav, Just downloaded it ans will go try now.
ref: let the PC cool down, it was cold as it hadnt been started for a week or 2.
speedy(delboy)
Do you mean run through the BIOS ??
If not then how ??
Have that programme on floppy but it wouldnt boot from it :cry: :cry:
You may need to enter the BIOS and change the boot order so it boots from CDROM first.
speedy(delboy)
DynaMight wrote:You may need to enter the BIOS and change the boot order so it boots from CDROM first.
I did gav :? :?
Any other suggestions, i would just re-install windows but the little un have millions of songs on it, and bless her she wants to keep them if possible.
No reason why the CD wont boot if the options are set correctly, unless the CD is buggered. Theres not much else you can do if you dont want to format the HDD, unless you have a spare harddrive to install windows on and see if it installs correctly, if it does the likelyhood is the hardware is ok.
Will it actually go into safe mode ? If it will, go in and copy the music files off.
If you put the windows CD in, and just run it in "repair" mode, I don't think it wipes the hard drive info :? in fact, even if you do a re-imstall, I don't think it does ........ but don't quote me on that one :roll:
Shove the Windows CD in, and see what happens ........ just don't actually click yes to anything "permanent" .....
What version of windows is it? if it's XP you should be able to chose a "restore point" of a couple of days / weeks ago ?
speedy(delboy)
TLS-Moose wrote:Will it actually go into safe mode ? If it will, go in and copy the music files off.
I downloaded the programe onto a floppy not a CD, but changed the boot sequence to A Drive and nothing.
I will not start up in Safe mode, it just keep turning off and then on again and so on etc etc
will run the windows CD in the morning and try repair and see what happens.
Cheers Guys
baskie
Re: PC Help Needed
Post by baskie »
speedy(delboy) wrote:My daughters PC wont start up properly :? :?
Anyone :?: :?:
exactaly the same thing happened to me? is it a copied version of windows. never did find out what the probelem was. i couldnt be arsed. just batter the shit out of it now its in a heap in my bedroom. :lol:
baskie
Post by baskie »
I did gav :? :?
take her hard drive off her comp. and stick it in yours. then just transfer them all over. stick the windows disck in. do the usual and then wen it works. (witch mind didnt) stick all her files back on. thats how u usualy does it wen it happenes. but didnt work this time :(:(:(:(
lowrider69
Post by lowrider69 »
this topic is old did you sort it out speedy(delboy) if not let me know i may be able to help out :wink:
http://bikesntatts.ning.com/
speedy(delboy)
Yep, all sorted, cant even remember now what was wrong.
Had a PC Engineer come and sort it, more money :cry:
