dash swaping
gavin
dash swaping
Post by gavin »
i have a anilog dash. would it be posibal to swap the dash to a digital dash.
cheers!! :)
p.s. sorry about spelling :oops:
furry
Post by furry »
Emmmmmmmmmmm bit of a grey area m8...
I got a TL1000R, and am in the process of fitting GSXR1000 K2 clocks...
What bike do you want to do this to, and what clocks did you have in mind?
TL1000R rulz :D
ZXR400Lee
Re: dash swaping
Post by ZXR400Lee »
I'm not sure if they would be compatible with your cagiva, dont see why not. I know places like Demon Tweeks, M&P sell aftermarket digital clocks.
Lee
furry
Post by furry »
Thing is you get combinations on a bike like this...
Cable RPM : Cable Speedo
Wire RPM : Cable Speedo
Wire RPM : Wire Speedo
I've never seen in my life a...
Cable RPM : Wire Speedo
Anyway I assume it's the speed you want Wired, in which case you need a singal to drive it...
If your bike currently reads the speed from a "Cable", it will be tricky, but not impossible to make it "Wire"
Getting the RPM in a "Wire" format if it's currently cable, is not a problem.
Also keep in mind different makes of bike, ie suzuki, honda, kazi etc, all use different ratios, so clocks are not interchangeable between brands.
Which Cagiva do you have, and what are the clocks currently on it?
TL1000R rulz :D
