Indicators stopped working
CBR_GRFT
Post by CBR_GRFT »
I have no mechanical knowledge and need some advice , basically as the title suggests my indicators do not work and i dont know what the issue is or how to resolve it. Can anyone give me any help as to what i need to check etc?
bikemad
Re: Indicators stopped working
Post by bikemad »
Dunno if its any help, but mine stopped working recently, and i took the fuse out to check it, gve it a little wipe on the metal bits, and hey presto, indicators worked again!
Has the bike been kept outside? Might be worth spraying a load of WD40 in the switchgear and see if that sorts it!
CBR_GRFT
Post by CBR_GRFT »
I replaced all my fuses yesterday and the bike is stored inside the garage and rarely is it stood in wet weather.
Would spraying the switch gear with WD40 really resolve the issue? as the there is no clicking noise either.
Bondy
Post by Bondy »
CBR_GRFT wrote:I replaced all my fuses yesterday and the bike is stored inside the garage and rarely is it stood in wet weather.
I would not use WD40.
Do you have an alarm. If yes does it flash the cators.
If you have and it does the problem could be relay or handle bar switch.
If you can find the relay bridge the poles that come from the switch. If they work its the switch if they don't its the relay.
And not all relays click these day.
Good luck.
Bondy
Post by Bondy »
Sorry forgot to ask.
What bike and what year.
CBR_GRFT
Post by CBR_GRFT »
Bondy wrote:Sorry forgot to ask.
Its a CBR400 NC29 1990.
my better half had this problem with her 400. I took the switch ggear apart and had to get surface corrosion off the copper switch contacts. Did that, applied a little vaseline and its worked ever since.
CBR_GRFT
Post by CBR_GRFT »
How easy is it to take the switch gear off? Seeing as im a novice.
delvey91
First Name: JACK
Post by delvey91 »
2 allen head bolts normally, or maybe screws?
2011 Yamaha WR450F
2004 CCM 404DS
CBR_GRFT
Post by CBR_GRFT »
delvey91 wrote:2 allen head bolts normally, or maybe screws?
Sweet , if i have time after work tomorrow i will give it a go , and hopefully it will solve the issue.
the copper contacts are inside the switch gear on the reverse part of the actual switch. Be careful not to loose the small spring and ball bearing in it.
Bondy
Post by Bondy »
You don't happen to work for Sparex do you. :?: I don't see many of them on my travels.
ahhh sumone else struggling with indicators! i've spent all day fukin round with mine.. :mrgreen: (and still only one works!)
Bondy
Post by Bondy »
TOM91 wrote:ahhh sumone else struggling with indicators! i've spent all day fukin round with mine.. :mrgreen: (and still only one works!)
Have you not got a volt meter or 12v probe.
Even a 12v bulb with 2 wires soldered to it.
check u have 12 volts to the swsitch then 12 out of the switch. Failing that bring them to mine, i am off today and tomorrow
