This happens when I deccelerate, which i believe means i have a rich mix.
things ive done recently:
1) changed exhaust from standard can to 'bass cannon' which creates a bit of back pressure and sometimes the bike would conk out after winding throttle down (not sure thats relevant tbh but sticking all the details up)
2) Balanced the carbs with new exhaust on (when I did this carb 1 had a tube that was going straight to fresh air, not the first time ive heard this, i got rid of this and linked the carbs up with the blocking plugs in between, not sure if this tube to air is something that has been done by a mechanic to combat another problem like 'rich petrol mix' - dont know how to adjust this and not sure you can on this model?), no popping or banging at this stage
3) changed the oil filter and put the standard can (oversized rocket launcher) back on.
4) went out for a ride and the sounds of shotguns going off fill the air
Any ideas guys and gals ? Cheers, appreciate any feedback
