My 04 Speed Triple is getting snatchy at low revs and even cuts out when blipped. Ive changed the plugs and air filter.
Where locally is the best place to take the bike to get it diagnosed and then set up to run really well?
Where best to get my Triumph tuned?
Re: Where best to get my Triumph tuned?
Bring it round to mine, can have a look for you, might be able to sort it for you or at least point you in the right direction.
2004 should be on injection and triumphs will have an obd plug,
At this age could be something simple like an air leak,
Si is handy with the spanners.
If it's anything more may be worth plugging in and seeing if there is any underlying issues.
CRMotorcycles
- First Name: Colin
Hellooo
If simon cant get anywhere ive got diag equipment on the van and can have a look for you ive had a few older triumphs play up with air leaks and throttle position sensor faults
Cheers Col
Cheers Col
- goatpants
- First Name: Chris
Has it got the latest map? I use tuneecu on my trumpets. DO NOT GO TO BRIDGE robbing b'stards!
Running on MT
