k5 gixxer 1000 exhaust throttle removal
philg
First Name: Phil
Post by philg »
Ey guys what's the benifit of removing the exhaust throttle on this bike
Tyia
Re: k5 gixxer 1000 exhaust throttle removal
Hi there, er, phil.
What's an exhaust throttle?
philg
First Name: Phil
Post by philg »
Meh my bad. There's a butter fly on the exhaust just before the can. It has a name but don't know it of the top of my head
Post by MellowYellow »
Reckon that refers to a butterfly 'choke' in the exhaust. My old man insisted on calling the 'choke' the throttle & calling the 'throttle' the accelerator.
Throttle and choke are indeed interchangeable when referring to some people. :-s
P.S. 2 pairs of LJ s this morning I think.
Kata
First Name: John
Post by Kata »
Mine has it off. I believe it's generally done so you can fit an aftermarket pipe.
I know I have a load of bits left over from its removal so it saves a little bit of weight too.
Best off asking at a specific GSXR forum for gsxr tech stuff though.
I would suggest you go to Gixxer.com or Gixxerboyz.co.uk they would have a better idea on performance mods to specific GsxR models. I can only advise on older models, sorry.
I would imagine though if its an exhaust butterfly linked to choke or throttle position it might mess up your ecu readings and cause the bike to run badly, you might be in the territory of needing dyno work and re flashing to get things re set with the Ecu / onboard sensors etc.? As I say I'm not familiar with newer K models so I'm just guessing.
I would guess it's like the exup on the Yamaha. It's to provide a bit of back pressure in the outlet to help it run smoothly at low revs.
If you remove it without a remap it will be lumpy at low revs impeding your pull away acceleration.
I would leave it in
Robbo87
First Name: Phil
Post by Robbo87 »
billinom8s wrote:..... It's to provide a bit of back pressure ........... to help it run smoothly .......
If you remove it ........... it will be lumpy at low revs impeding your pull away acceleration.
I would leave it in
Said the Actress to the Bishop.
Triumph Sprint ST 1050.
philg
First Name: Phil
Post by philg »
I had a look at the gixxer site for all of 5 mins. I will pop on there and have a search at some point
