GCMG
GCMG
Post by MellowYellow »
I have just, for the first time ever, changed a back wheel. It was diiiiiiiiiiiiiiiiiiiisgustingly grotty.
Swapped the wheel and NEW tyre off old girl I complete with rear brake assembly onto old girl II.
'Twas a little bit suck-it-and-see, but it's done.
:ymsmug: :ymsmug: :ymsmug: :ymsmug: :ymsmug:
Re: GCMG
Nice one. Front wheel next then?
Re: GCMG
Just need someone to test ride it for me now :twisted:
Re: GCMG
Leave it in the street with keys in.
Re: GCMG
Nothing fell off, no vibrations, 30 mls of scrubbing done.
Orf to Sammy Miller's on Sunday.
Re: GCMG
you should have washed the wheel first ;) .......or am I missing something..... :-\ :-\
Re: GCMG
billinom8s wrote:Nice one. Front wheel next then?
You knew. Didn't you ?
Haynes says "...and unscrew axle".
Translation...attack it for a couple of hours - give up.
Have a day off
Select a corner where sturdy railings meet at 90°. Rest wheel againt fence, rest outer fork against wall so that it can't rotate. Find 2 old leather belts and strap 'spoke' to railings.
Set torque wrench to max and set undo mode. Carefully balance on wall / fence / torque wrench and gently vibrate body in a vertical plane. Wait...CRACK. Nice or wott ?
:-bd
green_hodgeheg
First Name: pauline
Re: GCMG
Post by green_hodgeheg »
Back wheels do get really black. Years ago, I used to have a casual job doing tyres at things where people took their bikes down drag strips and my lovely job was to take the wheels on and off. :-)
Gimlet
First Name: Jim
Re: GCMG
Post by Gimlet »
This is why God created single-sided swinging arms.
And under-seat pipes.
KTM 1290 SuperDuke
Ducati 1098 Streetfighter
KTM 1190 Adventure
green_hodgeheg
First Name: pauline
Re: GCMG
My boss took the view that it was why God had created apprentices :-)
Re: GCMG
Been there, done that, yesterday.
Lump of wood, 1980s car jack, large hammer. Sorted. ~o)
Moley551
First Name: Martin
Re: GCMG
Post by Moley551 »
You road bike boys!!!.... try changing the tire with the ("pressure" still in it! = 14psi) in a field with no help allowed. New tyre and moose 5mins.
https://youtu.be/tPnQ67CVHXg" onclick="window.open(this.href);return false;
Moley551
First Name: Martin
Re: GCMG
Post by Moley551 »
or 44 seconds.
https://youtu.be/vJIi_giMIRA" onclick="window.open(this.href);return false;
Re: GCMG
MellowYellow wrote:Nothing fell off, no vibrations, 30 mls of scrubbing done.
I take it you did grease the axel before you put it back together again :80: and use the correct torque setting :erm:
Re: GCMG
menzies3032 wrote: and use the correct torque setting :erm:
Of course. The back one is 'really quite tight' and the front is between 'not too tight' and 'reasonably tight'. Much better than those EU megatons.
First ride tomorow... :-ss
