Tyre Wear.
Pebble
Tyre Wear.
Post by Pebble »
Got back from a 30 mile run on the motorway, When i checked the rear tyre saw bit's of rubber stuck to the tyre, Is this hot tear?
07749007862
Scotty
First Name: Simon
Re: Tyre Wear.
Post by Scotty »
I wouldn't expect so - were your pressures correct? If so I wouldn't lose sleep over it, just stay clear of motorways which will square your tyres off something rotten... :-s
Re: Tyre Wear.
Just looks like you gave it some beans and you have worn away some of the tyre. Don't think anything to worry about.
If your worried have a read of this might find it helpful
http://biketrackdayshub.com/motorcycle-tyre-wear-guide/" onclick="window.open(this.href);return false;
Pebble
Re: Tyre Wear.
Post by Pebble »
Thanks for the replies, I'll excellent are a bit slower and see how it goes.
07749007862
Re: Tyre Wear.
Were you two up??
graham22
Re: Tyre Wear.
Post by graham22 »
That's quite common to see on a warm motorway stint. Like Simon asked, were you 2 up or loaded with luggage, usually more obvious then.
Nothing to worry about.
Pebble
Re: Tyre Wear.
Post by Pebble »
One up, And excellerated hard down a straight. Slowed up now, and have not had a problem since. Had got a harder compound tyre on order, doing about 300 miles to work a week on motorway.
07749007862
Re: Tyre Wear.
Had a similar issue after monday and Wednesday.
Re: Tyre Wear.
Show off! :)) :))
