Remove gear lever?
Kookas
First Name: Ash
Remove gear lever?
Post by Kookas »
Hi, I've got half my GS in bits trying to change both sprockets and the chain but can't get this lever off. Undid the bolt and it moves on the spline but won't actually come off. The spline itself would rather move than let me take the lever off. Any ideas? Cheers
Re: Remove gear lever?
remove the bolt completely from the lever, walk away and then get a responsible adult to help :)): :)):
welcome to swb, pop along to the intro section and tell us a little about yourself, wha bikes you had before the GS?
let us know how the C&S swap goes and we'll see you at the pub meet next week ?
Ruffian
Post by Ruffian »
Have you removed the bolt completely or just loosened it?
As some are a pinch bolt, and some actually run the bolt in a channel on the splinew shafts
"Si beat me too it lol"
If it still refuses to budge with the bolt out jam a screwdriver in the slot and open the splines a bit it should slide off then
awkwardbydesign
First Name: aa
Post by awkwardbydesign »
Mervin wrote:If it still refuses to budge with the bolt out jam a screwdriver in the slot and open the splines a bit it should slide off then
The important part is "a bit". I have snapped a clamp by overdoing it!
