Work done so far,
strip and service forks
strip and service brakes - front and rear (very mucky)
replace rear shock
replaced rearsets
replace rear brake line
make new bracket for rear mastercylinder
replace front brake reservoir
service steering damper
oil change
filter change
clean k&n through
grease bearings in wheels
grease bearings in headstock
rescue chain
grease all rear suspension linkage
setup suspension on bike
replace rear sprocket
lube throttle cables and service throttle assembly
tidy wiring
strip bodywork and sand down for repairs
replace bolts with rounded out heads
sort bar ends
fix ignition barrel
bleed brakes
lube clutch cable
drain coolant and refill
make radiator guard
clean
phew
