Anyone in or near Kingsteighton?
As above, and if so, do you know anything about Autolink Southwest car sales place? Got a few ads on Ebay but googling doesn't bring anything up either positive or negative? Would be nice to hear an opinion if anyone knows anything. Thanks in advance!
http://www.ebay.co.uk/sch/autolinksouth ... 7675.l2562" onclick="window.open(this.href);return false;
- BMF
- First Name: Kim
Re: Anyone in or near Kingsteighton?
Actually alcohol IS a solution
Honda CB600S Hornet
Honda CB1300SA8
I'm in Kingsteignton, though have never heard of them. Can go have a quick look if you want, to save you a trip? Let me know what you want to know .....
Thanks, but that's for a dealer with a similar name in Portishead.BMF wrote:Found this: http://www.autotrader.co.uk/services/ca ... views/true
Very kind offer. I have been in contact with the geezer and the pictures look something like i'd expect a 12 yr old Transit to look like. By all means if you recognise the address and you're passing pop in , but don't worry about going out your way. He's not there today and I don't know whether the place is freely accessible or not. Meant to be popping down to have a look Monday unless anything else pops up closerer and betterer.TLS-Moose wrote:I'm in Kingsteignton, though have never heard of them. Can go have a quick look if you want, to save you a trip? Let me know what you want to know .....
There is a nice movano for sale on trackdayriders matt
Think thats a Renault Master(bater). I'm mainly allergic to french stuffRuffian wrote:There is a nice movano for sale on trackdayriders matt
If the place is where i think it is, and where Google shows it to be, then it's all locked up today
If you do go look at it, have a good look underneath. Transits (front wheel drive especially) of that age (02-06) can be very prone to severe rusting underneath ......
I agree with moose, those transits might be a buy cheap, weld 4000 times lol, bit hope I'm wrong for you.
As for the master/movanos there very good on that age up too the start of the new shape, (2010 on)
But each to there own and hope you find a good van,
So, did you go look? Was it any good?
No, you and Ruffian put me off old TranniesTLS-Moose wrote:So, did you go look? Was it any good?
Ad...http://www.ebay.co.uk/itm/142341436813? ... EBIDX%3AIT" onclick="window.open(this.href);return false;
Reg BT05ESV
https://www.check-mot.service.gov.uk/" onclick="window.open(this.href);return false;
He allegedly had someone looking today but that may have been salesman patter.
Haha, there's nowt wrong with trannies (we are still talking vans here?), but you do need to be aware of their propensity to turn into a pile of orange flakes. Get it treated and sealed and it will be OK. It seems an issue specific to UK built ones (mainly FWD).
To be honest, it doesn't look a bad van (almost interested myself ...... ) but the mileage blip could hint at an issue
My thoughts are the 01 to 06 was the best generation to drive and reliability. Only problem I had was melting the brake servo vacuum pipe
The 06 onwards wasn't very good for handling or reliability. Was recovered a few times.
ST4
DRZ400e
DRZ400e
I just looked at its mot history it has been moted today its scrap i reckon
MOT history of this vehicle
Test date 18 April 2017 Test Result Fail Odometer reading 148,301 miles MOT test number 3512 3774 9946 Reason(s) for failure
Offside Front Subframe mounting prescribed area is excessively corroded inner chassis leg (2.4.A.3)
Offside Front Upper Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Steering rack gaiter split (2.2.D.2d)
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Front Lower Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Front Lower Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Advisory notice item(s)
Nearside Front Upper Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Nearside Rear Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Rear Suspension component mounting prescribed area is corroded but not considered excessive both sides (2.4.A.3)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
rear chassis legs corroded
front inner wings corroded
rear inner wheel archs corroded and floor pan corroded and holed
all sills holed and corroded
exhaust corroded
top struts notchey
hand brake cable mounts corroded
exhaust corroded
top struts notchey
That's a fair list of welding!!
In fairness though, if gone through and done right, purchased for the right price (sub £1k) that could be a nice van.
