Under leather base layer
Hi all
Just got a new one piece set of leather.
Can anybody recommend best place to get some cheap one piece base layer as think the new suit might stick to me with a bit of Spanish track action.
Recommendations please.
Re: Under leather base layer
We just popped into the local sports direct,
Picked up some compression Base layers and used them.
Yes you can got for the full onesie under suit but the top and bottom's work well as separates also.
Like Ruffian said, try Sports Direct/JJ Sports type shops - Campri base layer long sleeve tops, often 2 for a tenner.
Lidl sometimes do their own but no cheaper than the above.
I've got a LIDL's set and they're pretty good, as is most of the gear LIDL & ALDI sell.
Yeah, anything that stops the sweat to the leather
- Scotty
- First Name: Simon
Yup, regular sports or "outdoors" shops have to be the way to go, try anything bike-specific and you'll end up paying several times the amount for something that's no different really. I use a ProSkins Onesie and it works a treat for getting leathers on and off - best get something with a "slidey" material and size it so it's a snug fit, you won't want any folds of surplus material bunching up
Steve McQueen
Steve McQueen
Other than those that are actually youScotty wrote:......... you won't want any folds of surplus material bunching up
Thank you all
I will nip into Sports Direct then. I had seen that they do the tops and bottoms but expected that this would not work as well but if this does the job then will go get some
Thank you......
Thank you......
Or ust go nekkid, and feel it rub against your flesh ......
sorry, mistook which website I was on .....
Footy shorts and long sleeved running top.
When in Portugal and Spain I didn't find that my legs were the issue anyways, was more the top half as thas what is doing more of the work,
Don't worry about multiples either as can wash in the sink and usually be bone dry by the morning also.
awkwardbydesign
- First Name: aa
Not cheap, but I always use silk top and long-johns, from Patra. https://www.patra.com/Category/Mens" onclick="window.open(this.href);return false; Unless the paramedics cut them off, they seem to last almost for ever. They keep me cool in summer and warm in winter. And wash out and dry really quickly.
ProSkins compression fit, worth every penny
Add a running top and you're sorted
- badgerKDD
- First Name: Badger
I find a tight fitting rubber suit helps me slide in and out of my leather one piece easily......
the tube from the facemask also allows me to drink without removing my helmet ;) ..............
badgerKDD wrote:I find a tight fitting rubber suit helps me slide in and out of my leather one piece easily......
