Ruffian wrote: ↑Dec 4th, '20, 17:29
Honestly I just couldn't be arsed with it, even if it was benificial. Just change the bike more often..
lol - I tend to hold on to my bikes longer.
But the issue is you almost need to release the tension off the forks to rotate otherwise could twist the springs internally.
Good point.. although I guess they would slip eventually in use to release any additional tension.
*Edit - thinking about this I don't think that happens as when the front is up (and the wheel is out) I often twist the fork leg but it never self straightens so the spring must be slipping.
Also if you rotate the forks it could actually cause issues in the fork seals.
I guess but whenever I have changed wheels I haven't worried about keeping each fork leg straight, in fact they often twist when trying to re-inset the disks into the calipers, and I have often twisted them 180 deg to give the insides a really good clean.
