DECEMBER - 10th Smileys Cafe, Honiton CANCELLED
Look in here for local ride outs...
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Meet at Smileys 09.30 to leave 09.45, fuelled for 115 miles.
Breakfast in Lynmouth
https://goo.gl/maps/gsmPq9SroFkFUEwT9
Pace will be making good progress according to prevailing conditions. Not hanging about for 125s but knee sliders not required either.
Weather dependant, so check here if I postpone to later in the month.
ptolemyx
Guest user
First Name: Brian
Re: DECEMBER - 10th Smileys Cafe, Honiton
Post by ptolemyx »
Anyone planning on joining me?
Robbo87
First Name: Phil
Post by Robbo87 »
Depending on: (a) an MOT'd Triumph (potentialy today), and (b) weather and finances (always unpredictable), I could be up for it. Will advise drekly.
Triumph Sprint ST 1050.
Tvrv37
First Name: Phil
Post by Tvrv37 »
It looks like I might have the day off work for this Brian, so weather dependent I should be in.
Robbo87
First Name: Phil
Post by Robbo87 »
ptolemyx wrote: Nov 30th, '22, 13:07 Anyone planning on joining me?
Sorry Brian, the Triumph whizzed through MOT but I'm keeping it on SORN until the new year so won't make this one. Have a good safe day.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
That's good, Phil the younger. Fully understand, Phil the elder.
Tvrv37
First Name: Phil
Post by Tvrv37 »
Forecast is looking like sub zero temps overnight untill middle of the day. That'll be out Brian as don't much fancy icy roads and freezing temps.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Yep, I'm keeping an eye out. If we have heavy frost overnight I'll cancel early in the morning. At 700 ft above sea level our village is a good gauge. If, as is likely, it's not that bad but still cold enough for the heated gear I'll change the route to avoid the higher bits of Exmoor.
So please check here to see if I cancel this ride in the morning...
ptolemyx
Guest user
First Name: Brian
Re: DECEMBER - 10th Smileys Cafe, Honiton CANCELLED
Post by ptolemyx »
Well, at 06.35 it's been snowing a couple of hours here. Pitching on the still frozen ground, current air temp -6 degrees which even the dog detested on our early trudge out of the village. Ponds in our garden stayed frozen all yesterday and today is forecast to be colder.
So, surprisingly, I'm staying relatively snug in the barely heated home and saving the route for another day.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Just dropped to -7...
Oo, any pics? I likes snow.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Here's our garden just before 2pm between the snow showers:-
Between? You had more than one session in the white stuff?
menzies3032
First Name: Robert
Post by menzies3032 »
Was proper cold this morning. Was scraping ice off everything this morning.
