HELP - whats the best way to get rid of rust and corrosion..
sprocket
Location: If ya sees me ya sees me | Cracked Silver K2SV650S
Post by sprocket »
Coat your front and rear subframe in black hammerite and replace all the bolts ... only way with a suzuki sadly. :(
[b][size=200][color=RED]DID A WET LAP AT NURBURG[/color][/size][/b]
Is it a bird? Is it a plane? No its a sprocket!!
Buy a Honda ;)
Post by chris_1127 »
kurust is useful stuff for killing rust off too - you either buy it as a solution or as crystals that you make into a solution but you just paint it on and it kills the rust and turns it purple. I usually use this stuff before i hammerite it
gsx-aaaaaaaargh!!!
