Broken side stand mount
Tvrv37
Post by Tvrv37 »
Below is a photo of the broken side stand mount on the Daytona 600 track bike. It didn't have a stand when I got it so bought a second hand one off fleebay. When I went to fit it I realised the reason it didn't have one, a broken mount. I thought I'd post the problem on here before giving up as it's a total pain not having one. I would appreciate thoughts on how to fix or permanently attach the stand. The mount is cast aluminium. Thanks.
Re: Broken side stand mount
Speak to Ruffian, he may well be able to make one and weld it in place.
Can either make a plate and drill/tap that mounting.
As welding to cast isnt usually successful.
Tvrv37
Post by Tvrv37 »
[dir=ltr][/dirltr]
Ruffian wrote: Aug 10th, '20, 23:02 Can either make a plate and drill/tap that mounting.
Where abouts in the world do you reside?
Tvrv37
Post by Tvrv37 »
I'm just about to lower the bike for Wendy so are you able to shorten the side stand at the same time?
He's in Wiland
Tvrv37 wrote: Aug 11th, '20, 05:06 [dir=ltr][/dirltr]
I'm in willand and yes can shorten the side stand also if needed.
you did that to my old pit bike i think, or at least welded it back together after stickly broke it over that jump.
