Recall
Recall
Post by MellowYellow »
Federation of European Motorcyclists' Associations
MANUFACTURERS' RECALLS
Due to oxidation, an electrical fault may occur in the brake-light switch of your Yamaha FJR1300, MT-10, MT-09, NIKEN, TMAX or XT1200 that is fitted on the handlebar brake lever. This may lead to malfunctioning of the cruise control, increasing the risk of an accident.
Due to humidity in the stop-lamp switch of your Zero SR/F or SR/S, the stop lamp may malfunction. This will increase the risk of an accident.
jer r1
First Name: jerry
Re: Recall
Post by jer r1 »
Not a good time for fjr1300's recall for 2nd gear issue resulting in need for full strip and rebuild as well as ecu reprrogramming to lower max torque in 2nd gear. We've now had a safe to ride statement from Yamaha UK after all fjr bloodbikes were taken off the road untill the recalls were carried out, so nearly a full fleet again except for the 2 bikes being done each week.
KEEP CALM
AND
POWER ON
goatpants
First Name: Chris
Re: Recall
Post by goatpants »
What years are affected?
Re: Recall
goatpants wrote: Feb 5th, '21, 20:11What years are affected?
The affected vehicles were manufactured between 2012 and 2020.
