I've just bought a Mk7 scottoiler to fit on my gsxr1000, Where is the best place to fit the reservoir, and where do i tap into the vacuum feed on the engine.
Thanks
Simon
Scottoilers - fitting help required
- speedy(delboy)
This is the technical page for Scottoiler.com
Have a gander.
Did you buy the Mk 7 Touring or Universal kit ??? The touring kit is the large res which is designed to go under the back of the number plate, where as the universal is designed to go under the pillion seat.
The URL below shows the GSX-R set ups that can be done
http://www.scottoiler.com/support_guide16.asp
Have a gander.
