Triumph part needed
svr-ash
Triumph part needed
Post by svr-ash »
A mate of mines got a trophy 900 and is having problems finding a part at a reasonable price so i said i'd have a look for him but i'm having problems getting the part number :(
The part is called the "Starter idler gear" according to the haynes manual, it sits between the starter motor and flywheel, tranfuring power from the starter
Ron Ayers don't do triumph parts so i couldn't look in there fiche which is my normal trick :roll:
If any one has eaither a Triumph motor they're stripping for bits, a friend doing the same or can get me really cheap Triumph parts (he got told over £100 for this small cog :shock: ) can they give me a shout with prices etc 'cause all he needs is to put this cog in, oil up and his rebuilds finished
CvPiper
Re: Triumph part needed
Post by CvPiper »
Most of the starter assembly is in a kit form. If you can verify the exact gear then I can see if its available. The reason most of it is in a kit as its an updated part to stop the sprag clutch wear when people have a low battery.
He can call Paul at Total Triumph 01823 358899 and he will get a genuine part, and the correct price. If its the one I think its not £100.
Total Triumph
Rides:
2014 Triumph Range ;)
07811110200
svr-ash
Post by svr-ash »
I was trying to get the part number so i could give a bit move info, all i got is a photocopy of the cog from a haynes manual if it's any help?
geoff
Post by geoff »
hi its the starter sprag clutch they can get damaged if you start the bike with a part charged battery which alows the engine to kick back upon starting also early triumphs had to have the cdi replaced to allow the engine to spin before fireing to stop this damage try sandy on 0144 3691666 for triumph spares in wales for used and new parts regards geoff
regards big geoff
