What is my clutch upto?
tutton
Post by tutton »
Just doing things to the bike to get it road legal after crashing its sat for best part of 6 months without being moved using the engine, got it running and everything back on and tightish (bar the mirror that came off and hit me at 60 haha) anyways i digress
When bike is started (in neutral) and then put into gear, bike straight away starts to pull away even with the clutch all the way in, i can move the lever in around 5/6 of the lever before i can feel any tension, but then even with the lever all the way in, its not letting the bike coast, its still creeping
Anyone got any suggestions please?
Sooner the better tis a bloody awesome day outside!
'94 FZR600R
'02 ZX636 A1P
delvey91
First Name: JACK
Re: What is my clutch upto?
Post by delvey91 »
just needs adjusting, i would of thought the info would be in the owners manual, or if its already at the end of adjustment then a new cable may be needed.
Should be easy to spot, where it meets the engine there will be and adjusmant point and at the handle bar end
2011 Yamaha WR450F
2004 CCM 404DS
thelastsuperpower
Post by thelastsuperpower »
Id say one of the following
Lever/cable adjustment
Old sticky oil needs changing
Clutch plates warped
Something else!
:mrgreen:
Bikeless again :/
jam
Post by jam »
It's just a dragging clutch, it sounds like the cable needs adjusting, adjust it until you have 3mm of free play at the pivot, which equates to about 15mm at the ball end. If it's hydraulic then you may well have an airlock in there, which is likely if you've had the bike over on its side. Just bleed it up as you would bleed brakes up, just don't expect the lever to go hard like brakes or you be waiting a long time :lol: If you reach the maximum adjustment on the cable screw adjusters and it is still dragging, then you may well need a new cable fitting.
DaveMcR1
Post by DaveMcR1 »
If its been standing unused for six months its unlikely cable stretch, more stuck clutch plates, but I could be wrong.
tutton
Post by tutton »
It was sitting for that long, but also now i think about it when i crashed the right bar ended up coming back with enough force to dent the tank, so possiblity the clutch cable was pulled enough to be stretched?
Ive tried the adjuster at the lever and thats doing little to no difference, where is the other adjuster situated?
'94 FZR600R
'02 ZX636 A1P
delvey91
First Name: JACK
Post by delvey91 »
2011 Yamaha WR450F
2004 CCM 404DS
I'm going to say that the cable needs adjusting too
graham22
Post by graham22 »
Failing the adjustment situ - have you replaced the clutch cover or had it removed? If so has the lift arm been put back in the wrong position?
tutton
Post by tutton »
Nah crash only went back to radiator really,
Well ive just put on the best it can be and now its almost completely out before it bites,
which means i can ride it, but i need a new cable i guess? and with it on this adjustment under hard acceleration its slipping for 2 seconds then just goes.?
'94 FZR600R
'02 ZX636 A1P
jam
Post by jam »
If the cable is still slack, yet the clutch is slipping then it's time for new plates, whilst you pulling it apart fit new springs as well, they're not expensive.
tutton
Post by tutton »
Nah cables either too loose or too tight, dosnt seem to be much either way, like its too long :S
does it alot now, everytime i remotly accelerate hard slips for a good 2 seconds then pops the front up as it comes onto power.
'94 FZR600R
'02 ZX636 A1P
syndony
Post by syndony »
I can push hard on the fork and it moves towards the front of the truck but it cant be push at all towards the back of the truck. Late last night I bled the line and got the pedal to work properly but it felt soft compared to before the problem.Also, I started it up this morning to see what would happen after replacing the master and slave cylinders.I put it in 1st gear pushed in the clutch pedal and turned the motor over.I let the clutch out and didn't move so I pushed the clutch in put it in 2nd gear and let the clutch out and it didn't move.
[url=http://www.r4-ds-card.ca]r4i gold ds[/url]
wanzey
Post by wanzey »
delvey91 wrote:at the other end....
http://www.fzrarchives.com/fzr600/600_m ... zr600r.pdf
LOL JACK! :mrgreen:
[b][color=#40BF00]Xbox Live Gamertag:[/color] [color=#FF0000] Mr Stabyyy[/color][color=#000000]Add me guys :D[/color][/b]
[IMG]http://i462.photobucket.com/albums/qq343/chavie23/poptartFINALTINY.gif[/IMG]
Daresay
First Name: Jez
Post by Daresay »
syndony wrote:I can push hard on the fork and it moves towards the front of the truck but it cant be push at all towards the back of the truck. Late last night I bled the line and got the pedal to work properly but it felt soft compared to before the problem.Also, I started it up this morning to see what would happen after replacing the master and slave cylinders.I put it in 1st gear pushed in the clutch pedal and turned the motor over.I let the clutch out and didn't move so I pushed the clutch in put it in 2nd gear and let the clutch out and it didn't move.
:shock: What the........ is that all about ?
[img]http://i686.photobucket.com/albums/vv224/strangledtiger/mybanner4a14770f7253d.jpg[/img]
