2003 GSXR 600
Battery is reading bang on 12.5v, the bike has been ridden most days for the last week 1-2 hours at a time.
When you turn the ignition to 'on', the bike primes itself, does it's fancy thing with the speedo and once the digital 'check' has gone from the screen it's when you next hit the start button.
Some times it will start fine no problems. (In neutral, stand up, kill switch off and clutch pulled in). About a third of the time it will start and doesn't sound like the battery is tired - all good.
The rest of the time, you hit the start button and it doesn't attempt to turn the starter over at all, there's no 'clicking' sound from the relay and the lights don't dim, all it does is make the priming fuel injection noise when you hold the start button down, and when you let go it stops.
This means I have to bump start the bike every time! .It bump starts easy and then rides with no problems. Any suggestions?
Cheers!
