OMG coca cola is bad for you, big time.
Some more info on just how good coca is good for you - in a parallel universe !!! :shock:
10 minutes after consumption
Drinking a can of coke is equivalent to 10 heaping tablespoons of sugar, which is 100 percent more than the recommended daily intake. At the 10-minute mark, the body has welcomed the full amount of sugar mentioned. Wondering why vomiting, or even feeling nauseous, is not typically experienced despite the massive amounts of sugar consumed? This is because phosphoric acid tames down the flavor, preventing consumers from becoming sick of the overwhelming sweetness.
20 minutes after consumption
Sugar levels inside the body shoot up, causing a hormone called insulin to fire up. The liver reacts to this increase by turning excess sugar, which is quite abundant at this time, to fats.
40 minutes after consumption
Caffeine is absorbed into the body at this time. The body responds to this through pupil dilation and blood pressure elevation, which prompts the liver to release more sugar into the blood. The brain also becomes affected since the gates or receptors that receive adenosine, a central nervous system depressant, gets blocked. The said blockage causes individuals to stay "high."
45 minutes after consumption
The dopamine levels inside the body increase, activating areas of the brain responsible for feelings of "pleasure." The effect is said to be similar to that of heroin.
After 60 minutes of consumption
Multiple reactions happen within the body after an hour of consumption. The metabolism of the body shoots up as phosphoric acid attaches to calcium, magnesium and zinc found in the large intestine. Calcium levels within the body are then decreased as the elevated amounts of sugar boost its excretion via the urine.
Further diuresis will also take place, making people urinate more. The frequent urination or plentier amounts of urine excreted mean that water and electrolytes, which should head to the different parts of the body for nutrition, get dumped out of the body.
Sugar crash then follows as the elevated bodily actions start to wane. Individuals at this point become irritable, and all the water contained in the Coke also gets depleted, bringing with it all the electrolytes that should have been used by the body for nutrition.
Kata
First Name: John
Re: OMG coca cola is bad for you, big time.
Post by Kata »
I'll have a pint instead then...
How much sugar is in a pint then?!
Smiler
Rideout Ringleader
Post by Smiler »
A really rather effective cleaner too! Brings chrome up beautifully apparently...
Ask yourself, if it does that to metal, what does it do to your insides???? :shock:
No ta.....haven't drank coke in a lonnnnnnnng time
There again, wine is bad for you - Stomach acid, alcohol, etc. But wine is also good for you - reduces cholesterol, reduces risk of heart disease. Salt is bad for you - heart disease, but essential for you in replacement of that lost through perspiration, etc. So many things that are "bad" for you are also essential for the bodies survival.
Ever looked at a coffee cup that hasn't been washed? Or a tea-pot? Noticed how so many herbs and spices stain whatever they touch?
Who here is foolish enough to subscribe to buying water in plastic bottles? Known carcinogens in the manufacture of the plastic leaches into the water over relatively short periods of time, and is worsened if exposed to UV (normal daylight).
For everything you can put in your mouth (!) there will always be examples of how if you have too much/not enough of said item being bad for you.
The trick is, have whatever you like, just in sensible quantities. And use water from the tap.
As an aside, ever seen what stomach acid (that what is naturally produced & in you all the time ;) ) can do to metal??
If drinking Cola is bad for you, imagine what the ' Experts' would make of riding a bike at high speed on a track day, or even worse a 'spirited' ride on UK roads....I haven't done that in a long time either ;) ......
My Mum was very clean living, never smoked, ate sensibly, rarely drank, walked in the countryside regularly, yet she got Lukemia and died way before her time. Eat what you like, drink what you like, do it all in a bit of sensible moderation, scare yourself regularly and die knowing you lived a full life ;) .
