40L of paraffin
Latest information on South-West-Bikers...
40L of paraffin
I need to get hold of some, does anyone know where they sell it on tap please?
Thanks
Re: 40L of paraffin
you could try a local heating oil supplier, see if they will sell ya a couple of drums of heating oil its the same stuff basically ,
Re: 40L of paraffin
Post by MellowYellow »
B & Q do gallon jugs
Re: 40L of paraffin
Brother is (was) an organic chemist.
He says try Tincknells, Avonmouth.
01749 673 661
Re: 40L of paraffin
Mervin wrote:you could try a local heating oil supplier, see if they will sell ya a couple of drums of heating oil its the same stuff basically ,
Thought heating oil was basically diesel?
Re: 40L of paraffin
It seems that kerosene in the US is what we call paraffin.
Here, however, kerosene refers to aviation fuel and is NOT the same as paraffin.
Re: 40L of paraffin
Cheers, yeah,the price b&q sell it at makes it too expensive..
Re: 40L of paraffin
Afaik Kerosene /heating oil is basically paraffin , it is reffered to as 28 second burning oil , and paraffin was a slightly cleaner burning version for indoor portable heaters etc , Kerosene is also aviation fuel for jet engines , i have a mate that used to be in the business , the 28 second bit is the time it tke 50 ml to run through a small test hole , where as diesel and Gasoil (red diesel ) is thicker and takes 35 sconds to run through the same hole , if you only want the stuff for cleaning oil off things or for a parts cleaner go to a garage that sells red diesel or if you know a freindly farmer see if he will sell ya a drop , it will be cheaper than a garage for sure ,
http://www.heatingoilshop.com/products.php" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.portland-fuel-price-protecti ... i-have-no/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
