So the bike went over to Si with a load of new fluids and list of jobs to do as long as your arm which included:-
Remove and clean Forks then refit
Change Fork Oil
Remove and clean Shock then refit
Regas the Shock
Change engine oil
Change engine oil filter
Drain coolant
Refill coolant and bleed the system
Remove and clean brake calliper
Fit new brake pads and refit on the bike
Not only was a top job done but so blooming quickly he only had the bike a few days
Cost wise well impressed for such quality work. I bought all the parts and fluids so just paid Si for the work he completed but I have bought biking boots that cost more then all this lot
Well impressed
So if your planning on getting some work done, strongly recommend you give him a call for a quote first
