didn't realise they'll need re-building at 7-8kjaagsxr wrote:hi m8 cos mine is the smr the engines only last 7-8000 miles and then they need a new con rod
so it is a full strip down new main bearings gaskets and a rebore , oh and larger piston and rings
so not that cheep around £1200
i got a bloke who raced huskys for 7 years to do the work cos he could rebore it.
but i later broke a crank case and i rebuild it when that happened, and crank cases are only £1200+vat!!
and do i notice the difference ??well yer a bit , you can run larger gears so more speed and exceleration![]()
but i only did mine because the engine needed a refresh.
Ahh, well if/when it needs to come apart il think about it then, you running standard gearing? I may try to go up a few teeth for a bit of top end as theres plenty of grunt low down.
G
