Sunday September 29th LATER START 1.00p.m.
Look in here for local ride outs...
Shooey
First Name: Paul
Re: Sunday September 29th
Post by Shooey »
Red5 wrote: Sep 23rd, '19, 12:23
menzies3032 wrote: Sep 11th, '19, 20:33 and that makes 3 of us. I am also at Pembrey and due to my fat unhealthy body will be in no fit state to do another ride the day after a track day :-t 8-|
FFS Robert... 2 of us have used Pembrey already.Come up with your own excuse will ya =)) :)) :x
Ming
First Name: Andy
Post by Ming »
Alas, I have no bike....
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Honda NC750X DCT - sold
Red5
Post by Red5 »
Ming wrote: Sep 23rd, '19, 14:29 Alas, I have no bike....
What's happened Andy? hope that's scheduled no bike and all's ok :-bd
Ming
First Name: Andy
Post by Ming »
Not exactly scheduled..... It was booked in for a check of the rear brake that's been getting overheated which should have been a short visit this Saturday. However, in the middle of Spain last week it pissed fluid out 2 or 3 times overnight. Expansion tank remained full and the rad's been leaking but not drawing fluid in from the tank. I had to strip the plastics off each day and top up the rad direct. I've a feeling S and P are going to have it for a while.....
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Red5
Post by Red5 »
Ming wrote: Sep 24th, '19, 05:56 Not exactly scheduled..... It was booked in for a check of the rear brake that's been getting overheated which should have been a short visit this Saturday. However, in the middle of Spain last week it pissed fluid out 2 or 3 times overnight. Expansion tank remained full and the rad's been leaking but not drawing fluid in from the tank. I had to strip the plastics off each day and top up the rad direct. I've a feeling S and P are going to have it for a while.....
Sounds impressively fussy. Hope they can fix it easy enough. Sounds like a blockage with the radiator unable to breath properly through the expansion tank....
Any clues of the rear brake over heating?
Keep us updated. Curious about the coolant issue as dealing with similar on the flying korma.
Ming
First Name: Andy
Post by Ming »
I'm convinced the rear disc is out of round, causing it to overheat the pistons/caliper/fluid when it's used. This has been going on since new but S and P think it's normal for the disc to go blue and the pads to wear out quickly.... when the only time it's used is when I have a pillion or to keep the bike steady on slow tight turns.
They've had problems with faulty thermostats and also well documented problems with loose hose clips. I'm not impressed, that's for sure
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
"This has been going on since new but S and P think it's normal for the disc to go blue and the pads to wear out quickly.... when the only time it's used is when I have a pillion or to keep the bike steady on slow tight turns."
Sounds like you need to try a workshop that knows what they're doing...…...
Ming
First Name: Andy
Post by Ming »
They were relating what the company line is with regards to warranty work. Straight forward things like leaking exhausts and water leaks they'll address no problem. When there "could" be an element of user error they are more difficult to persuade.
Neighbour had a similar issue with his new Street Triple wearing the rear disc and pads in under 4k miles. Bridge said Triumph refused to cover it under warranty as they inferred he was resting his foot on the lever during riding.
I guess KTM think the same thing. But I KNOW the disc is out of round as when I spun the wheel with pads removed the disc is slightly larger at one point as it touches the spring plate in one area only. If it was perfectly round it wouldn't happen. Whether this alone is enough to cause the overheating I don't know. Could be the pistons are dragging as well. Disc doesn't look warped but when you push it after it's been ridden there is a low pitched squeaking noise from the disc at one point each revolution.
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
chr1s
First Name: Chris
Post by chr1s »
Ming wrote: Sep 24th, '19, 12:48 They were relating what the company line is with regards to warranty work. Straight forward things like leaking exhausts and water leaks they'll address no problem. When there "could" be an element of user error they are more difficult to persuade.
Any decent mechanic could sort out that disc issue in minutes with a simple dial gauge, out of true or not..
Hope you get it sorted soon mate.
Ming
First Name: Andy
Post by Ming »
Cheers Chris. It's the annoying little problems like this that's pissing me off, and the time the bike's off the road because they won't let me have a loan bike. At least Bridge gave me one when my Tiger 800 had a gearbox problem under warranty.
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
chr1s
First Name: Chris
Post by chr1s »
I’m really surprised they didn’t give you a loan bike at least, that’s crappy. I’m guessing, but could be way off, that is an issue with KTM and not the dealer, dunno. It’s not a good start to the new relationship though!! SP have only recently started with KTM as well I think...Wonder if it’s worth calling KTM direct and having a firm conversation?
Ming
First Name: Andy
Post by Ming »
S and P say it's a condition of their insurance that the bikes have to stay in their premises overnight. Not really a KTM problem, more an insurance thing. They'll let me have one for a few hours if it's in for a service but not overnight, and I'm not convinced they'll fix it on Saturday which is the first day they can look at it.
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Blender81
First Name: Ben
Post by Blender81 »
Could the issue be as simple as no free play at the lever or too much fluid in the system? both are reported issues I've read about causing similar problems on an RSV forum. You may have considered these already of course
APRILIA RSV gen1....Bbrrrraaaaaaappppp
Oh yes.....The rideout is still on folks :mrgreen:
Ming
First Name: Andy
Post by Ming »
Blender81 wrote: Sep 25th, '19, 06:24 Could the issue be as simple as no free play at the lever or too much fluid in the system? both are reported issues I've read about causing similar problems on an RSV forum. You may have considered these already of course
Yep, checked both these things and they're bang on. I run with quite a bit of free play as I don't have much feeling in my feet so I'm used to the lever having to move a fair way so I know when it's operating.
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
