Castle Combe Track Day Noise Limit
Look in for Track days + events
DaveH
Post by DaveH »
I have an unexpected day off on Wednesday so I'm thinking about doing the track day at Castle Combe. Do you know if my Ducati 848 is likely to pass noise testing on Termis with baffles or do I need to put standard pipes on?
Re: Castle Combe Track Day Noise Limit
Hi Dave, i know that they are very strict there!! so standard cans maybe the way ahead....
i heard that if you fart too loudly at castle combe they black flag you
Yeah, but it's kind of a mockery when you get full on Group B rally cars, open-piped Ferrari's, roaring yank V8's, etc., at events like RallyDay held there ....... :cry:
nick:L
Post by nick:L »
The measured distance from exhaust is closer than most tracks use I think so DB figure alone can be misleading, a number of stock bikes can fail at CC, so I would recommend a cautious approach
http://www.castlecombecircuit.co.uk/tra ... mation.asp" onclick="window.open(this.href);return false;
Smiler
Rideout Ringleader
Post by Smiler »
A friend with her Gsxr750 failed noise test there Dave, I'd take a back up plan if you're going :wink:
Smiler wrote:A friend with her Gsxr750 failed noise test there Dave, I'd take a back up plan if you're going :wink:
cobrabuilder
First Name: Darren
Post by cobrabuilder »
Jolz just passed with her srad 750 on standard can I thick it's 105dbs but I think they test abit closer
scorcher
Post by scorcher »
pretty sure Crazycraig had his 848 on standard pipes fail at Combe. But there was a 1098 there on Termis that had made it on track. Make of that what you will! :)):
layne
Post by layne »
Its tested at 3/4 of the max revs NOT ACU testing. 1/2m from the exhaust is the norm.
With the YZF 750 I bent the needle back 1500rpm and pasted ok.
Andy on his RSV-R with dB killers noticed that the guy wasn't watching the rev counter when he was reading the meter. So he rev'ed it about 2000 rpm less than the block asked for and only just passed. It sounded obvious to me that he wasn't reving it but we got through.
Didn't get pulled on track when we were using the throttle properly :lol:
