Coolant question
- Jay
- First Name: Jay
Coolant question
OK recently ive noticed that the bike is getting hotter than normal...Then when i stop and turn off the engine, Coolant/Water comes out of the resivour over flow....
The level is fine but a litle concerning.
Any ideas??
Thanks in advance.
Any ideas??
Thanks in advance.
Re: Coolant question
Hmm radiator is not blocked stopping air flow through it is it ? has it a fan , has that stopped working?
- Jay
- First Name: Jay
Not blocked and both fans work.
water pump?
Water pump circulation?
echo, echo, echo
Blocked thermostat then,
Not pressurised once left overnight is it??
Thermostats get grotty. Take it out (keep it) do a few miles, see if that works.
Yes - get new T
No - put it back.
Yes - get new T
No - put it back.
You can get test kits to see if there are hydrocarbons in the coolant, to see if it is being pressurised by a weakening head gasket .......
- Jay
- First Name: Jay
All sorted.....
Gave the system a good flush through with a hose in the rad .....after a good flush then refiled system IAW the manual and job done....
Did you back flush the rad? , put hose in outlet at bottom , and shove water back up through the rad
