Coolant question
Coolant question
OK recently ive noticed that the bike is getting hotter than normal...Then when i stop and turn off the engine, Coolant/Water comes out of the resivour over flow....
The level is fine but a litle concerning.
Any ideas??
Thanks in advance.
Re: Coolant question
Hmm radiator is not blocked stopping air flow through it is it ? has it a fan , has that stopped working?
Not blocked and both fans work.
water pump?
Ruffian
Post by Ruffian »
Water pump circulation?
echo, echo, echo :)):
Ruffian
Post by Ruffian »
Blocked thermostat then,
Not pressurised once left overnight is it??
Post by MellowYellow »
Thermostats get grotty. Take it out (keep it) do a few miles, see if that works.
Yes - get new T
No - put it back.
You can get test kits to see if there are hydrocarbons in the coolant, to see if it is being pressurised by a weakening head gasket .......
All sorted.....
Gave the system a good flush through with a hose in the rad .....after a good flush then refiled system IAW the manual and job done....
Did you back flush the rad? , put hose in outlet at bottom , and shove water back up through the rad
