Hi all,
I am after a nice warm pair of gloves for commuting. The ones i currently have, have served me well and they are giving up the ghost. I commuted from Truro to Fareham on the 600 with out heated grips last night and it's time to have a new pair....
So what are you all using and what's your recommendations?
Glove recommendations please.
- Jay
- First Name: Jay
Re: Glove recommendations please.
Best thing i have found are these gloves designed for working in freezers very water proof and very warm , maybe a bit short but i use em , and only about a fiver a pair
No specific recommendations on brands or models but might want to consider heated versions. I know you have heated grips on the BMW but going for full on heated gloves / body warmer is the way to go if your riding in sun 10 deg temperatures, rain and wind
I've found that a pair of silk / satin liners help a lot.
https://www.jasminesilk.com/silk-gloves ... clavas/c57
- Guest user
I use Gerbing XRL heated gloves with silk inner gloves on my heated grips when it's particularly cold.
https://gerbing.co.uk/collections/motor ... ycle-glove
- Jay
- First Name: Jay
No protection with those bad boys
- Jay
- First Name: Jay
Yes sounds good, but no heated grips on the 600... i miss my BMWmenzies3032 wrote: ↑Mar 14th, '22, 20:23 No specific recommendations on brands or models but might want to consider heated versions. I know you have heated grips on the BMW but going for full on heated gloves / body warmer is the way to go if your riding in sun 10 deg temperatures, rain and wind
- Jay
- First Name: Jay
I may try this before shelling out on those Gerbing gloves as mentioned by PtolemyxMellowYellow wrote: ↑Mar 14th, '22, 22:00 I've found that a pair of silk / satin liners help a lot.
- Robbo87
- First Name: Phil
You can try 'em and they may help a bit - I have and they helped stave off blue fingers for around an extra 20 minutes but Jack Frost will get you in the end for sureJay wrote: ↑Mar 15th, '22, 08:14I may try this before shelling out on those Gerbing gloves as mentioned by PtolemyxMellowYellow wrote: ↑Mar 14th, '22, 22:00 I've found that a pair of silk / satin liners help a lot.
https://www.jasminesilk.com/silk-gloves ... clavas/c57![]()
Triumph Sprint ST 1050.
