Glove recommendations please.
Hi all,
I am after a nice warm pair of gloves for commuting. The ones i currently have, have served me well and they are giving up the ghost. I commuted from Truro to Fareham on the 600 with out heated grips last night and it's time to have a new pair....
So what are you all using and what's your recommendations?
Re: Glove recommendations please.
Best thing i have found are these gloves designed for working in freezers very water proof and very warm , maybe a bit short but i use em , and only about a fiver a pair
menzies3032
First Name: Robert
Post by menzies3032 »
No specific recommendations on brands or models but might want to consider heated versions. I know you have heated grips on the BMW but going for full on heated gloves / body warmer is the way to go if your riding in sun 10 deg temperatures, rain and wind
Post by MellowYellow »
I've found that a pair of silk / satin liners help a lot.
https://www.jasminesilk.com/silk-gloves ... clavas/c57
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
I use Gerbing XRL heated gloves with silk inner gloves on my heated grips when it's particularly cold.
https://gerbing.co.uk/collections/motor ... ycle-glove
Mervin wrote: Mar 14th, '22, 20:07 Best thing i have found are these gloves designed for working in freezers very water proof and very warm , maybe a bit short but i use em , and only about a fiver a pair portwest-thermal-a450-cold-weather-hi-vis-glove.png
No protection with those bad boys :) but i bet they do work though.
menzies3032 wrote: Mar 14th, '22, 20:23 No specific recommendations on brands or models but might want to consider heated versions. I know you have heated grips on the BMW but going for full on heated gloves / body warmer is the way to go if your riding in sun 10 deg temperatures, rain and wind
Yes sounds good, but no heated grips on the 600... i miss my BMW =)) She is having a sleep in my warm garage :)):
MellowYellow wrote: Mar 14th, '22, 22:00 I've found that a pair of silk / satin liners help a lot.
I may try this before shelling out on those Gerbing gloves as mentioned by Ptolemyx :)
Robbo87
First Name: Phil
Post by Robbo87 »
Jay wrote: Mar 15th, '22, 08:14
You can try 'em and they may help a bit - I have and they helped stave off blue fingers for around an extra 20 minutes but Jack Frost will get you in the end for sure :( . With the kind of commuting you gave as an example earlier there's no substitute for keeping your mitts dry and out of the wind - obviously. So you've got tons of options starting with heated grips as a minimum, then heated & waterproof gloves, then barkbuster style handguards to help keep some of the wind off etc. etc. Considered bar muffs? Ugly perhaps but if you've got room to fit 'em they've got to be the D B's.
Triumph Sprint ST 1050.
